Temp Gauge
Old May 8, 2018 | 05:27 PM
lrnoob's Avatar
Default Temp Gauge
For those of us with OBD1, what aftermarket temp gauges do you guys run?
Old May 8, 2018 | 10:45 PM
fishEH's Avatar
I've got a cheap digital readout one in my '94. Used a cheap water temp adapter spliced into my top radiator hose. Works very well.
Old May 14, 2018 | 01:35 PM
grenade's Avatar
Where did you splice it in exactly? I've done the same thing and am getting some random readings from my Autometer Gauge. I am on the down-slope from the highest point of the radiator hose, with the sensor in the 6'oclock position. Im thinking about moving it to just before the inlet of the radiator.
Old May 19, 2018 | 09:56 PM
Johnny K's Avatar
please keep us informed. i am just in the exact process, but havent cut the rad hose., where are you mounting the autometer? i have the 4337 model, but cant decide where to put it- terribly little room in the cab...
johnny
Old May 20, 2018 | 11:15 PM
robertf's Avatar
I did this when I ran external gauges
It's the plug on the bottom of the intake manifold. Vehicles other than Discovery used it, but its a blank plug that takes a lot of force to remove the first time. Bored it to clear a socket, then tapped to 1/8" npt. Bored the back for coolant to get around the sensor.
Since it is NPT you could probably get away with a drill if you didn't have a lathe, but I wouldn't want to do that.
Old May 22, 2018 | 01:41 PM
fishEH's Avatar
The temp sensor on my '96 is in this location. I just used a bushing rather than drill and tap the plug.
The one in my '94 uses the inline hose adapter, 38mm.
I'm running different gauges in each truck. The one in the '96 seems to read about 10 degrees cooler than the ECU reading.
Old May 22, 2018 | 04:27 PM
robertf's Avatar
have you compared the 94 temp gauge with rovergauge?
Old Jun 11, 2018 | 12:13 PM
robertf's Avatar
New option for gauge mounting
http://shpws.me/QoNn
that one looks rough because it was printed on a cheap $400 printer. The shapeways stuff looks really good and is much more durable than printed ABS
Old Jun 11, 2018 | 03:05 PM
ihscouts's Avatar
More useful than a clock.
Old Jun 11, 2018 | 09:19 PM
Johnny K's Avatar
Oh. I am.buyimg one of those. That is exactly- exactly what I was thinking of doing from scratch. Thank you!
