Is there A
Is there A
Cross reference list of parts that fit the D1 from other car types?
I know plugs and such but MAF and other parts might be the same under ANOTHER make and be cheaper. If I order a relay for the 1978 rolls it is $175.00. from Rolls but If I just use the part number and I bought the same relay for $65.00
The fan clutch from a 2000 Chevy Express with the 4.3 NO a/c fits.
The IACV from a Jeep 4.0 fits but may not work properly and the dealer will not program it for you.
Wheel bearings are standard Timken.
U-joints are $20...the most expensive part for the DI other than a engine or trans is the MAF, thats $1500 new.
Everything else can be had for cheap if you know where to look.
In other words, yes, you can Disco on a budget.
What is this then???
INTERCHANGE BOSCH 0 280 218 010
(0280218010)
ROVER MHK 100800
(MHK100800)
Application
Description Year KW HP CC LAND ROVER RANGE ROVER II(LP) 3.9 07.1994-03.2002 140 190 3947 LAND ROVER RANGE ROVER II(LP) 4.0 06.1998-03.2002 136 185 3950 LAND ROVER RANGE ROVER II(LP) 4.6 07.1994-03.2002 165 224 4553 LAND ROVER RANGE ROVER II(LP) 4.6 06.1998-03.2002 160 218 4554Our price : $79.95
http://www.deluxeautomall.com/land-r...10-p-3264.html
If this is true Mutley will get one ASAP
(0280218010)
ROVER MHK 100800
(MHK100800)
Application
I had not heard the FIAT in MANY YEARS
(0280218010)
ROVER MHK 100800
(MHK100800)
Application
(0280218010)
ROVER MHK 100800
(MHK100800)
Application
Yeah their selling junk.
Here is their DI MAF.
http://www.deluxeautomall.com/index....525&year_id=42
Ain't no $80.
Ain't no $80.
