Which thermostat?
Old May 17, 2023 | 04:30 PM
Sherlock's Avatar
4th Gear
Default Which thermostat?
I’m getting a 180. But which one, and from where? No to motorad; I’m clear on that. Otherwise any one I can find will do?
Old May 17, 2023 | 06:39 PM
Sherlock's Avatar
4th Gear
For example, this one? Listed for a Disco II but will it work for ours???
https://www.roverparts.com/engine-co...ts/PEM100990G/
Or should I just get a thermo and install into the existing housing…?
Old May 17, 2023 | 07:59 PM
JohnZo's Avatar
The Genuine Land Rover t-stat is great IMO. Stick with that and you will be fine. D2 has a different set up than D1.
Old May 17, 2023 | 08:55 PM
Sherlock's Avatar
4th Gear
Can I get one that’s 180?
Old May 17, 2023 | 09:02 PM
Best4x4's Avatar
Any 180F with a jiggle pin works fine.
Old May 19, 2023 | 01:11 PM
WaltNYC's Avatar
The Stant 45858 is my preferred t-stat.
Old May 19, 2023 | 02:09 PM
jvarnadoe's Avatar
I also use the Stant 45858, which is a 180 degree thermo. I installed it around 5 years ago and it's still going strong. The Stant 45858/Nissens 64029 radiator combo keeps me in the high 170, low 180 range.
Old May 20, 2023 | 05:07 PM
drivendesign's Avatar
I can't seem to find a 45858 online from the usual suspects? Are there any decent alternatives?
My water pump imploded yesterday. Luckily I was 250 yards from my destination!
Ordered a FlowKooler replacement and a Hayden 2991.
Old May 20, 2023 | 11:50 PM
jvarnadoe's Avatar
Ya, I wonder if they discontinued that part #? I did find it at RockAuto. They only have one on a wholesaler closeout for $1.81. Grab it quickly!
STANT 45858 180 Degree; Superstat ® Thermostat Info
Category: Thermostat [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$1.81
Add to Cart
Old May 21, 2023 | 08:43 PM
Damn missed it. That was listed as a Motorad? I thought those were to be avoided or are they the same?
