which tie rod end is lh thread?
Old Sep 4, 2016 | 08:19 AM
lestro's Avatar
Default which tie rod end is lh thread?
97 discovery USA model, which end is the left hand thread?
Old Sep 5, 2016 | 03:53 AM
loanrangie's Avatar
Assuming your trackrod is the same, it should the passenger side (RH ) tierod and all other are RH thread.
Old Sep 5, 2016 | 07:34 AM
lestro's Avatar
thanks
Old Sep 5, 2016 | 07:19 PM
mr4x4's Avatar
here's a kit with all four of them for 50 bucks shipped. My tie rod's boots are cracked but are not wobbly so not sure if i should replace them.
Land Rover Disco 1 Def RR Classic Steering Tie Rod End Set RH LH RTC5869 RTC5870 | eBay
Old Sep 5, 2016 | 09:25 PM
lestro's Avatar
I just twisted off the wheel end of the drag rod. Seems it was left hand thread. Going to have to replace the drag link.
Old Sep 6, 2016 | 02:35 AM
loanrangie's Avatar
They might be ok but the OEM Lemforder rods are about $45AUD each so that says something about the quality.
Old Sep 6, 2016 | 07:56 AM
OverRover's Avatar
If you are going to replace all 4 tie rods (& you should) then LEMFORDER is the way to go. Never had an issue with these on LR, BMW, MZB, etc....
From Lucky8, hell of a price and well worth it! > Land Rover Discovery 1 Defender Classic Steering Tie Rod End Set RH LH Lemforder | eBay
Old Sep 6, 2016 | 06:24 PM
fishEH's Avatar
If you're looking for a drag link there's some D1's on the AutoPartsCity in Waukegan, IL.
Otherwise Paul Grant or Drillbit on here should be able to get you a good used one.
Old Sep 6, 2016 | 08:54 PM
lestro's Avatar
thanks, I got the stub out with a little heat
Old Sep 6, 2016 | 09:13 PM
fishEH's Avatar
Nice! Where in IL are you?
