Tie Rod Ends
Excuse my ignorance, what's "zero fitting"?
Do you mean zerk fittings? For the TRE's? If so, there are TRE's you can buy with the zerk fittings already installed.
Good luck getting the old TRE's out. Use plenty of heat and penetrating oil. If you've ever considered going with heavy duty drag link and track rod, now is a good time to do it. It'll save you the headache of removing the old TRE's from your old rods.
1998DiscoverySE
02-10-2012 11:00 AM
