Timing Chain 1998 Disco 1
Old Jul 25, 2011 | 10:22 AM
Chris-bob's Avatar
With proper maintenance, timing chains, cams and lifters, main and rod bearings should last forever(nearly). Once you have an issue with heat or contaminants, then the components start to wear and never stop wearing until they fail. There is nothing you can do to stop the wear once it has begun.(aside from replacement of said failing part)
It is, however, a good idea to inspect the timing chain and gears if you have access to them. If there is minimal play, then don't worry. If the play is excessive, replace.
Old Jul 25, 2011 | 08:09 PM
Exactly.
Mine has 205k on it and runs great, old Buick engine it is not anymore, it has been upgraded many times and oils are better now at protecting wear than they were even 10 years ago.
A well maintained engine should last damn near forever.
Even a abused one will last 150k.
Rover engines are no different than a Chevy or Ford push rod engine, they all have the exact same parts the only difference is where they were made.
Racing engines wear different than daily drivers, higher RPM, longer run time at high RPM, more heat, more load, more extended load, etc.
Comparing apples to oranges with the daily driver compared to the racing engine.
Old Jul 25, 2011 | 08:13 PM
Originally Posted by Clunker
Spike555,
It was a 2001 Saturn 4 cylinder. 160k. Not the finest car in the world, but it still came as a surprise. I thought even in cheaper cars engines went well beyond 200k. This vehicle was very well maintained. The good news is a used engine with 70k is $700 and the install is $550.
That had a timing belt didnt it?
I agree that the non free wheeling interference engines are a bad idea, almost all overheat cam engines are that way.
The timing belt breaks and the crank and pistons continue to move but the came and valves stopped where they were when the belt broke, the pistons come up and smash the valves and either bend them or punch a hole in a piston or two.
Old Jul 25, 2011 | 08:15 PM
Nope, timing chain, with a recall no less.
NHTSA Recalls Saturn L Series
Old Jul 27, 2011 | 06:53 AM
Clunker's Avatar
What was the recall for?
Old Jul 27, 2011 | 08:27 PM
The TSB on the Saturns was for a defective timing chain.
No love from GM either from what I read, it broke and it was all on you.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
Duncan Campbell
May 19, 2011 08:19 PM
FTB 2000 Disco
May 15, 2007 07:49 AM
mrach21061
Apr 25, 2007 11:54 AM
