Timing Cover/Water Pump Bolts
Old Mar 7, 2018 | 10:33 AM
lrnoob's Avatar
Default Timing Cover/Water Pump Bolts
So, genius here neglected to mark where each bolt came from on the timing cover and water pump. I know the three little ones are for the pulley, and the 6 short ones are for the pump to cover. Do I have the rest correct? I also suppose I'm missing one where the pink ? is. Any idea what size that one is?
Attached Thumbnails Timing Cover/Water Pump Bolts-1.jpg   Timing Cover/Water Pump Bolts-2.jpg
Old Mar 7, 2018 | 10:39 AM
DavC's Avatar
Somewhere, maybe in the workshop manual there is a description of each bolt by length for this purpose.
If you find that all you do is measure and sort that way. In the future take a piece of cardboard, trace the outline of the water pump or draw it, and stick each bolt in the cardboard so it matches its spot on the pump, useful for timing case also etc.
Old Mar 7, 2018 | 02:09 PM
OverRover's Avatar
Maybe this might help.
Old Mar 7, 2018 | 03:06 PM
lrnoob's Avatar
It is! Thank you!
A5scott
Jul 11, 2015 07:25 PM
outdoor7or24
Dec 22, 2014 09:31 PM
CaptainCulp
Dec 13, 2014 07:23 AM
