Tire Check
Old 05-21-2012 | 08:03 PM
LeakyDisco's Avatar
Default Tire Check
Yes, I know, another "Which tires should I get..." post.
I have mostly decided on which tire I want (Cooper Discoverer ST/Maxx 235/85/r16), but my main questions are:
With an OME 2" HD lift (shocks + springs), will a 235/85/r16 fit without any adjustments (steering stops, etc.)?
Will that narrow of a tire be OK with a fully-loaded compliment (roof rack gear + 4 adults)?
Cheers,
- Chris
Old 05-21-2012 | 10:05 PM
jafir's Avatar
That tire is no narrower than the stock tire on a D1. The width doesn't really have much to do with load carrying capacity. 3/4 ton and 1 ton trucks have been known to come with that size tire.
Old 05-21-2012 | 10:13 PM
LeakyDisco's Avatar
OK. Then I suppose it should be fine.
I don't want giant tires; just something that will fill the wheel wells a little better with the 2" lift, but continue to perform fine on and off road with no major mods.
Old 05-21-2012 | 10:15 PM
LeakyDisco's Avatar
As far as the tire brand, I like the Cooper. It looks good and the quality seems good. Also, Spike has talked it up a bit and all the reviews I have read support his endorsement.
Old 05-22-2012 | 09:52 AM
fishEH's Avatar
You'll probably want to do some minor trimming on the back of the rear wheel fenders.
Old 05-22-2012 | 10:35 AM
ValveCoverGasket's Avatar
ill let you know, im getting my 235/85s today :P
Old 05-22-2012 | 11:15 AM
LeakyDisco's Avatar
Out on the Internets I've seen both "must cut" and "not necessary" so I guess I'll just have to go for it and see.
Old 05-22-2012 | 11:16 AM
LeakyDisco's Avatar
Pictures please!
Old 05-22-2012 | 11:46 AM
Pictures please!
planning on it!
i ordered some rear spring spacers to have around anyway, but not expecting to need them. may put them in for towing regardless...
Old 05-22-2012 | 11:48 AM
filbs's Avatar
Quick Reply: Tire Check
