Trailer Towing
Old Jul 29, 2013 | 10:33 PM
lkearnest's Avatar
6th Gear
Default Trailer Towing
I own a 1998 Disco 1 and need to know if it is safe to tow a load weighing 3400 lbs. (trailer and cargo weight combined) I have a double axle enclosed trailer and no trailer brakes hooked up. Driving a distance of 100 miles, with a $10000 Can Am Commander as cargo, so some definite jack on the line here.....what do you think is this a bad idea?
Old Jul 30, 2013 | 12:37 AM
The RAVE manual set includes the owner manual. From that we have:
Unbraked trailers .................................................. . 1650 lb (750 kg)
Trailers with brakes - high range ........................... 5500 lb (2495 kg)
Trailers with brakes - low range ............................. 7700 lb (3490 kg) -
Roof rack load .................................................. ..... 110 lb (50 kg) **
Maximum permissible tongue weight .................... 330 lb (150 kg
So hook up the trailer brakes..... it is important to note that your insurance policy might go ***** if your were not following established procedures. Most small trailers are insured by the tow vehicle, check with your agent to be sure.
Old Jul 30, 2013 | 04:31 AM
antichrist's Avatar
Most state laws require trailer brakes for that weight anyway.
Hooking up trailer brakes isn't a major undertaking anyway.
Old Jul 30, 2013 | 07:53 AM
lkearnest's Avatar
6th Gear
Thanks. This is the best forum on the Web, thanks to guys like you!
Old Jul 30, 2013 | 08:12 AM
And thank you. Think you can bull the Disco out of a bog with the Commander?
nickm347
Apr 19, 2011 02:11 PM
Disco2Fever
Mar 14, 2009 03:49 PM
Rosembelt
Feb 5, 2008 05:47 PM
equestrianmom
Nov 1, 2007 05:26 PM
sanfranca
Sep 22, 2007 01:37 AM
