Transfer case issues?
Old Nov 12, 2022 | 11:21 AM
Tomtom17's Avatar
3rd Gear
Default Transfer case issues?
All right so what I have is a 1998 Land Rover Discovery 1 what I've been having an issue with and whenever I try to shift my transfer case and it either high or low and make this awful planking sound and then finally after doing that for about a month it blew up so I got a new transfer case and transmission went ahead and replace both of them and now I don't have drive or any of my moving gears and I don't know maybe I hook something up wrong or what but I am looking for advice as this is my first discovery and first time being Land Rover owner.
Old Nov 12, 2022 | 12:00 PM
Greg_M's Avatar
You put the ATF in?
Old Nov 12, 2022 | 02:57 PM
Best4x4's Avatar
Sounds like it's in N vs High or Low TC wise, or you have air in the transmission lines and the torque converter isn't full of ATF. You added ATF then ran the engine and shifted thru the gears then checked the level again?
Old Nov 12, 2022 | 03:19 PM
Tomtom17's Avatar
3rd Gear
Default Yes it has ATF in it
Has ATF on bow TC and tranny, but still no moving gears. Has park and neutral.
Old Nov 14, 2022 | 11:02 AM
WaltNYC's Avatar
The transfer case in a D1 takes 80-90w gear oil, NOT ATF. Transmission DOES take ATF.
Though I doubt that is your direct problem. It does sound like the TC is in neutral. As best you can, try to push the lever in the cabin toward the right (passenger) side of the vehicle, and pulled toward the rear of the vehicle (in other words, "down / right") which will be high range / open differential.
https://www.roversnorth.com/parts/bt...shift_defender
Tomtom17
Nov 12, 2022 10:45 AM
ciglesias
Mar 11, 2017 10:38 AM
SWAINROVER
Dec 5, 2015 04:38 PM
br3nt
Jan 24, 2007 01:45 AM
ajh
Oct 23, 2006 09:42 PM
