Transfer case knock when coasting
Hi
My 98 disco 1 just started to produce a knock whenever i take the foot off the gas pedal. I can feel it if i rest my hand on the transfer case selector.
the transfer case operates well and shifts well in low or lock. It whines lightly but i have to turn everything off to hear it, so i doubt it comes from it.
The u joints look ok but I can't be sure : how do you check them?
Anything else i should check?
Thanks for any hint
Thanks for any hint
I'm having the same issue with my 98 disco. It's not as bad since I replaced the rear driveshaft but sometimes when I step off the gas or when i shift it into reverse I hear a clunk noise. Ill check my fluids as recommended though. I have a pretty good idea how expensive a "used" transfer case is, so are there any other alternatives in a worse case scenario? Anything like rebuild kits etc?
