Transmission????
I'm thinking the transfer case high range gear is binding or bound, my thought since I read your first post. If the case can be brought to neutral or low the transmission should be able to be shifted into neutral just to get an idea. I would block up both axles if you can to get the wheels off the ground to rotate them just to make sure it isn't one of those diffs that's hosed.
Maybe some of the guys here can help move this a little further along tonight, I gotta hit the hay for a long day tomorrow, already had two long days so far and am beat.
No sir. I can push it now, with rear driveshaft unhooked at differential. Front is still attached. But no I push in the brake with key in 2 position, it's stuck in park.
The first time I tryed this it went into neutral, but couldn't get the transfer case into N. I pushed forward pretty hard on the transfer shifter. Then when I returned to park it wouldn't come out of park.
