Transmission fill plug?
I guess you already sorted it out thanks to previous posts. I liked your one comment about how similar but not similar the DI and DII are. I remember a Land Rover ad that touted over 720 differences between the old Series 1 and the new Series 2. Now, with an R380 you have even more differences. Whenever looking for advise or help with your DI you always have to preface your question with a statement about it being a 5 speed. I learned that with my '85 Range Rover.
Just an update for future viewers.
The transmission fill plug on these 5 speeds also known as R380 can be removed with a size 55 Torx socket.
The drain plug is a 32mm. Its tight so I used a 32mm speed wrench.
Fluid: Redline MTL 70W80 or 75W/85
_________________
So different than the D2
_________________
Ya that’s what I thought too!
I spend a bit of time on the site searching and it appears Land Rover sent out an update saying to switch to MLT.
AntiChrist confirmed this in an older post:
https://landroverforums.com/forum/di...n-fluid-52277/
