Transmission fluid and/or filter change; Opinions needed!!
notice replacing the filter (which is actually a metal screen) is a repair item not a maintenance item, however if you are leaking from the trans sump pan it may be better to drop it and replace the screen at the same time. Just keep in mind the exhaust y pipe and middle cross-member must be removed to access the filter.
kpl1228
04-20-2012 06:22 PM
collin Barrows
08-28-2011 07:13 AM
Travelor
08-23-2011 07:48 PM
treant985
12-27-2010 02:51 PM
