trouble starting.
Old Jul 17, 2010 | 10:45 AM
turf63's Avatar
Default trouble starting.
My truck won't start. Lent it to a buddy last night, the alarm was armed, he unlocked it with the key and not the fob (shouldn't be an issue) and tried to start it but it won't turn over. When you crank it you get power and one click. Nothing else. The alarm dashlight also freaks out, blinking really fast. I replaced the starter in Nov so I'm hopeful its not the starter. Went out this morning cleaned my terminals thoroughly. Cleaned the ground point to the frame and it still won't start. Tried jumping it, same story. Power, and one click. I haven't had time to check the starter solenoid ground but I'm about out of ideas and of course my landrover dealer service dept isn't open on Saturday. You guys have any thoughts? I need this truck to work. Thanks.
Old Jul 17, 2010 | 01:34 PM
greg409's Avatar
have you tried lock/unlock several times with fob?
the dashlight blinking fast leads me to believe it's the alarm not liking you locking with fob and unlocking with key.
luck,greg
Old Jul 17, 2010 | 02:55 PM
AK Rover's Avatar
The starter disable part of the alarm has been tripped. Lock/unlock the door 3 times with the key and it should clear.
Old Jul 17, 2010 | 03:58 PM
turf63's Avatar
I'm at work now but getting out in an hour. I'm thrilled at the possibility of this being an easy fix. I'll let you guys know asap. Thanks.
I didnt see any literature in the manual about that. Youd think they'd mention it.
Old Jul 17, 2010 | 05:44 PM
turf63's Avatar
i tried the lock unlock method 3 times with the fob from the outside, no luck. Way more than three times from the outside, no luck. Tried it locking/unlocking via the key in the door, no luck. Tried turning it to accessory and leaving it for 30 seconds then turning off again and starting, no luck. Any other ideas? I'm 95% sure its the alarm, the click when i turn it over really sounds like an alarm kill on the starter.
I need help. thanks guys
Old Jul 17, 2010 | 06:45 PM
greg409's Avatar
Maybe your buddy left something out, did you try resetting the inertia cutout ("I forgot to tell you I was jumping cars with it") switch pass side under hood on firewall black button?
Just a thought.
Luck,greg
Old Jul 17, 2010 | 06:59 PM
Long Haul's Avatar
I think you have to have the key in the ignition turned to #2 position and lock unlock 3 times with the fob.
Old Jul 17, 2010 | 07:17 PM
turf63's Avatar
tried the inertia switch, no luck. Tried the ignition in position #2 lock/unlock but it doesnt work (fob wont lock or unlock) in position two, tried it in position #1 and the three unlocks didnt work. Now, i'm starting to think maybe its not an alarm issue, maybe its the starter solenoid. I replaced the starter 12/09 but it was an advanced auto parts refurb unit. It has a lifetime warranty so im thinking i may have to pull the starter tomorrow and take it to them to bench test it. My area landrover dealer wont be open till monday for service inquiries so i guess i'll just try this.
Sound like the next plan of action?
Old Jul 17, 2010 | 07:33 PM
Long Haul's Avatar
I sthe truck fully in park?
Im runnin out of ideas
Old Jul 17, 2010 | 08:10 PM
Arm and hammer's Avatar
Did you try jump start the starter motor?
