turn signal flashing fast
Old Oct 10, 2017 | 06:21 PM
Clay Stanley's Avatar
Exclamation turn signal flashing fast
So I have an issue with my turn signals blinking fast.
Both left and right blinks fast, but normal with the hazards, Checked and cleaned all the sockets, all lights are working as they should.
Im lost on what to check.... need advice.....
Old Oct 10, 2017 | 06:24 PM
Icannap1's Avatar
Did you just upgrade to LED lighting if so you need to add a resistor to the rear turn signal lights, if you did not upgrade to LED check that all of your bulbs are working it can also happen when exterior turn signal lights are out.
Old Oct 10, 2017 | 06:29 PM
no LEDs, all lights are working. 4 lights on each side.
Old Oct 10, 2017 | 10:23 PM
Fender indicators are good?
Old Oct 10, 2017 | 10:25 PM
yeah, every light thats supposed to be flashing is.
Old Oct 11, 2017 | 08:47 AM
fishEH's Avatar
Aftermarket bumper(s)?
Old Oct 11, 2017 | 11:08 AM
jimvw57's Avatar
Might be a defective flasher (old school)
Old Oct 11, 2017 | 11:44 AM
Where is it located?
Old Oct 12, 2017 | 12:57 AM
Icannap1's Avatar
Z128 is the flasher if you have a D1.
Old Oct 12, 2017 | 04:23 PM
alright, I thought that was just the relay for it, I need to find a replacement and try it and see if it fixs the issue.
