turn signals / marker lamps
Old Sep 21, 2014 | 02:58 AM
Dabigkahuna's Avatar
Default turn signals / marker lamps
Wanted to say thanks to all the members who have taken time to share their knowledge for others. I purchased a 98 disco and it had a number of issues starting with the old brake light switch, compounded by rear wire ground short and bad third brake light, with the stuck park solenoid and key jammed in ignition thing. Thanks to this forum all have been repaired. So I now have what hopefully is a stupid question. Most vehicles orange turn signals also act as marker lights (constantly illuminated) when first position on headlight switch is engaged ( second position being headlights completely on ). This does not happen on mine and after watching online footage of disco1's driving at night, this seems to be normal. Just wanted to verify that signal lights both front and fender side remain completely off until turn signal engaged even with headlights fully engaged. Praying I don't have to spend another day off tracking down wires and can go fishing. Its my first posting so flame on!!
Old Sep 21, 2014 | 07:28 AM
ihscouts's Avatar
Go fishing, they stay off.
Marker lights are in the bumper end caps and most don't work anymore because the bulb sockets have rotted.
Old Sep 21, 2014 | 11:16 AM
fishEH's Avatar
I'm glad you brought this up. I think you can get double pole bulb sockets for a P38. Install a dual filament bulb and connect the extra lead to a parking light circuit.
Bulb Holder Dual Filament (XBP100190 Same Fit As Part # XBP100190 ) - Land Rover bulbs from Atlantic British
Just need a pigtail I think.
Old Sep 21, 2014 | 12:45 PM
The original bumper was switched out for the land rover tube bumper with the headlight guards however the bumper end caps don't seem to be there. Not sure if I will be able to pass the safety check without the lights so thanks for the idea on the dual filament socket and bulb, I may need it. As usual this forum rocks.
fishEH
Sep 23, 2014 08:11 AM
rambo
Oct 17, 2013 10:13 PM
Street Wolf
Jul 12, 2012 05:20 PM
2004FXD
Oct 23, 2007 07:54 AM
SpeedAgent
Jul 16, 2007 08:56 PM
