Tyre size? what lift?
Old Sep 13, 2012 | 07:13 AM
mattdisco1's Avatar
4th Gear
Default Tyre size? what lift?
hi guys,
I am new to the forum and i was just wondering if anyone could help me out with some info.I have just purchased a 97 disco 1 and i would like to know your thoughts on a 2" suspension lift and 2"body lift.The reason im asking is and im sure its been asked 100 times,if that 285/75/16 will fit with this lift? thanks matt
Old Sep 13, 2012 | 09:07 AM
fishEH's Avatar
Yes 285/75/16's will fit with a 2" suspension lift and a 2" body lift.
Old Sep 13, 2012 | 10:06 AM
Possibly with a little trimming also.
What are you going to do regarding the diff's that are quite weak as stock and with 285's you will be needing gears, HD axles and lockers to support a 33" tire when playing hard.
Old Sep 13, 2012 | 11:47 AM
fishEH's Avatar
DM brings up valid points. Much of it will depend on how hard you wheel, if at all. You won't necessarily need all that stuff, but it wouldn't hurt. The main thing to remember is to take it easy on the skinny pedal, don't spin your tires. A locker and HD axles and/or very good articulation will help you crawl over obstacles slowly instead of cowboying over them at speed and spinning tires.
Old Sep 13, 2012 | 08:35 PM
mattdisco1's Avatar
4th Gear
Thanks guys much appricated
Old Sep 14, 2012 | 04:35 AM
Jake1996D1's Avatar
Whats a "tyre"?
Old Sep 14, 2012 | 08:58 PM
tweakrover's Avatar
It's the European spelling for tire, geez get out some will you.
Old Sep 14, 2012 | 10:57 PM
MrFister's Avatar
I have a 2" lift with 285's on it. "Camel Cut" and it works well. Only a little rubbing on my Right Front Radius arm at full right steering which I just haven't adjusted yet.
I know the list of parts everyone else gave you is pretty spendy cause I got the same list. But don't overlook some basics like Rotoflex eliminator because your lift will eat those up like candy, and +2 shocks so you get the full benefit of your lift.
I got my shocks from Lucky8.
Also I've been on a couple difficult trails in colorado without lockers and axle upgrades. Might not be the best idea but do-able.
Old Sep 14, 2012 | 11:31 PM
Jake1996D1's Avatar
I was joking. Were not in Europe. It's a TIRE
Old Sep 15, 2012 | 04:30 PM
tweakrover's Avatar
I know I find it hard to use a sarcastic tone while typing.
