Ultragauge & Engine Load
Old Jan 5, 2018 | 09:09 AM
hrhoward's Avatar
Default Ultragauge & Engine Load
How does the Ultragauge come-up with the engine load percentage? It'll read up in the upper 90's just taking off from a stop. Level ground, 2,500-ish rpms. Running fine and no dragging brakes, bearings, etc.
I haven't gotten around to addressing this yet, Fuel Trim Wacky
Old Jan 6, 2018 | 12:10 AM
number9's Avatar
I haven't checked load with my ScanGauge in a couple of years and never did so under similar conditions.
It does take mucho energy (seen measured by engine load) to move our heavy vehicles from a stop. What is the duration of the 90% load reading? There are options to change the speed of parameter updates on the ScanGauge and the Ultra may have the same.
Old Jan 6, 2018 | 02:40 AM
robertf's Avatar
(Mass flow rate * air temp * ideal gas constant R )/ (engine displacement / 2 * engine speed ) * 100%
The ratio of air flow vs displacement*rpm
Toran
Sep 17, 2016 01:25 PM
thatbaldguy
Aug 8, 2016 07:20 AM
EstorilM
Mar 11, 2016 06:33 PM
SFMaster1703
Apr 3, 2014 06:39 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
