Uneven suspension? Alighnment and tires.
![Exclamation](https://landroverforums.com/forum/images/icons/icon4.gif)
I hesitate to even ask- but I Recently took note how the rear passenger side of my Disco is noticeably lower the the rear drivers side. Any ideas why or what I'm dealing with? My concern is that perhaps the lift was installed incorrectly or that a critical part of my suspension is broken.
I'm fixing to get a full alignment done in afew weeks, with this said might the uneven height of my disco make getting an alignment now pointless? Should I fix whatever the issue is with the height, THAN get the alignment or does it really matter at all?
I'll take afew pictures today when I get out of work, of the rear and attach them in this thread.
Yes fix the suspension first, if you need to take things apart you run the risk of messing up the alignment.
I would normally say its a broken spring, but you have a brand new lift so it must have been installed wrong.
The springs are what hold up the truck, the rest of the suspension is just for driver comfort and control.
The only things that effect height are tires (same size and inflation needed), springs and weight in the car.
If you have 500lbs of bricks in the back it will sit lower than the front.
If you have a tire that is under inflated it will sit lower on that corner.
If you have a broken spring or a upside down spring it will sit lower on that corner.
Sometimes a broken spring isn't that noticeable unless you know what to look for. They can crack under that nice shiny plastic coating, an you won't see the cracks, especially if the springs are dirty. compare them side to side and see if any of the wraps in the coils are closer together on one side versus the other. On my D1, one of the rear springs broke, and you could tell because at the bottom of the coil on one side of the truck they wraps were almost touching each other. Then when I wiped off some dirt I could see the broken spot.
Hmm ill wipe both springs clean then inspect them then snap some pics. Well in a worse case scenario if the spring is broke ( either the previous owner was to rough with the rig or these springs are cheap quality junk!) How do I go about the repair? Just buy 1 replacement spring? Or are springs like tires: when you replace one you have to replace the the spring as well?
