V8 internal coolant leak
Old 11-18-2014, 02:53 PM
ninehads's Avatar
8th Gear
Default V8 internal coolant leak
Hi, so I have a 1994 disco 3.9 V8 with 168k miles that is new to me for about 8 months now. I noticed a yellow-ish goo in the oil cap and the breather thing... Since I have it I only ran about 100 miles with it, and the coolant level in the expansion tank dropped maybe 1/2 inch. The engine run fine (but takes 3-4 seconds to start) and don't overheat so I'm not sure if the head gaskets may have a leak. I was also thinking that coolant may leak behind the timing cover. I checked the dipstick but no trace of coolant there.
Any suggestions where to start? I just don't want to open everything for nothing...
Old 11-18-2014, 03:00 PM
TOM R's Avatar
if its just in the fill cap it COULD be just from condensation buildup/ not running the engine long enough, lots of short trips only lasting a few minutes where the engine never realy gets to operating temp.
if your losing coolant might want to do a pressure test, lots of places to leak that you would not normaly notice like loose hose clamps etc
Old 11-18-2014, 09:26 PM
ninehads's Avatar
8th Gear
I checked that and no loose clamps... The only thing leaking out of the engine is oil, from the valve covers and front crankshaft seal...
scottiedoo1975
Freelander
02-07-2010 01:38 PM
rambo
Engine & Internal
03-24-2009 01:16 PM
rasta4x4usa
10-02-2008 08:14 AM
rasta4x4usa
09-29-2008 07:57 PM
Byte
05-20-2008 08:23 PM
Quick Reply: V8 internal coolant leak
