Vibrating brake pedal?
It was icy out this morning and whenever I came to a stop while driving, the brake pedal would start vibrating and making a clicking noise. Not at first, but right before I came to a full stop. Im thinking it might be abs. The abs light comes on when I first start it up, but it turns off when I start driving.
Any suggestions?
Any suggestions?
That would be the ABS keeping you from sliding by modulating the brakes. As far as coming on when you start up, if that is beyond the normal 3 seconds Power On Self Test (POST) that most of the warning light do, it deserves more investigation. You can take out the ABS fuse in the underhood box for diagnosis, some don't like it and drive with it disabled.
Things I've done so far...
New brake pads
New serpentine belt
New fuel filter
New fuel pump
New spark plugs
New muffler
Cleaned throttle body
Rotella 15w 40 oil
New air filter
Flushed brake fluid
Fixed frozen CDL
I plan to...
Change t-case fluid
Change diff fluids
Coolant flush
