water leak
water leak
After replacing the pump today, My 95 disco is leaking water from the thermostat housing area? and water hose. I truly can't say where is leaking precisely from but I am concern that I might have a major problem. Can some one advice? I truly welcome any input regarding the possible causes if this leak. Thanks
mr4x4 (08-29-2016)
Thanks!
I have seen the thermostat hose and water is leaking from the hose at the thermostat housing. I will replace the clamp and see if the leaking stops at this particular area. It would be easier fix, If the the problem is at the hose rather than the thermostat gasket.
This are the things I replace in this service:
1. New water reservoir tank.
2. New tank cap.
3. New water pump with new gasket
4. New thermostat and gasket with new bolt.
I welcome any other comment. I will keep you updated with pictures.
Thanks!
G.
