water leak
After replacing the pump today, My 95 disco is leaking water from the thermostat housing area? and water hose. I truly can't say where is leaking precisely from but I am concern that I might have a major problem. Can some one advice? I truly welcome any input regarding the possible causes if this leak. Thanks
get some engine cleaner/ parts cleaner and clean it all off good.....start her up and take a flashlight to the thermostat housing, pump gasket and front cover area...you should be able to see it better
Was pump leaking prior to replacement? Asking because often stopping one leak will add enough additional pressure to get a weak link to leak.
Thanks for your respond!
Thanks!
I have seen the thermostat hose and water is leaking from the hose at the thermostat housing. I will replace the clamp and see if the leaking stops at this particular area. It would be easier fix, If the the problem is at the hose rather than the thermostat gasket.
This are the things I replace in this service:
1. New water reservoir tank.
2. New tank cap.
3. New water pump with new gasket
4. New thermostat and gasket with new bolt.
I welcome any other comment. I will keep you updated with pictures.
Thanks!
G.
Yes! I will check in all of the areas you are mentioning.
