Waterless Engine Coolant - Jay Leno's Garage
#21
I found an interesting piece in a web search that was a bit too pro DexCool but it did include a cool tip regarding the use of a multimeter to check coolant quality. Has anyone seen this before?All About Dex-Cool® - GETAHELMET.COM
#22
There are simple turbidity, refractometer and simple conductance meters made just for this that will give you general "condition" reading. They basically are just measuring too much/too little coolant to water or too much salt/ions in the solution.
As the major concern/problem of the coolant is the chemical salts forming from bad water, contamination, electrolytic reaction, etc. You can use a multimeter to test the conductance of the solution but unless you have a specific gap setup or the correct probe it can be kind of an un-exact science. Fresh DI water and pure antifreeze will have a conductance of theoretically zero but the additives in most of the antifreeze will increase this and if your water isn't DI it will have a high conductance.
On my 2005 Range Rover they used the (re-labeled) and double priced up BMW Blue Coolant that worked well until they switched it with DexCool after almost the first service and it caused a lot of corrosion. They also skimped a bit on the mixture and type of water as the pressure blew out the cheap BMW reservoir and several hoses very quickly.
jfall
05-11-2017 11:37 PM
BoeingBoeing
Sights N Sounds
02-17-2014 11:06 AM
