Waterproof your ECU (PRODUCT)
Old May 23, 2011 | 05:39 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Default Waterproof your ECU (PRODUCT)
Ran into a new product while purchasing plastic resin for my next project. Thought I would share this. Looks simple, just poor it in.
EpoxAcast® 650 It is used for electrical encapsulation to extend the life cycles and enhance the performance of potted electronic devices.
EpoxAcast® 650 Mineral Filled Casting Epoxy Resin | Smooth-On
Old May 23, 2011 | 06:30 PM
swank1975's Avatar
Wonder what that does heat wise
Old May 23, 2011 | 07:06 PM
LRD2&ME's Avatar
It is an already enclosed caseing, surrounded by conductive metal, which produces static. I'll bet it works just fine.
"An encapsulant, also know as a potting compound or casting resin, is a liquid resin system comprised of either one or two components that is poured over electrical and electronic components. It can either be in an enclosure such as a plastic shell or case or it is poured into a mold holding the components where the cured material acts as the shell. These encapsulating resins are designed to electrically insulate and environmentally protect the components from moisture, chemicals, mechanical/thermal shock and vibration. This protection allows these electronics to be used in many more applications ensuring reliable, long-term performance."
Everything I have read so far shows that this material is excellent in heat dissipation.
Old May 23, 2011 | 07:27 PM
Long Haul's Avatar
I have used that stuff to waterproof my RC cars and planes electronics before, it works great. I never had any thermal issues using it, my plane speed controller without it would run about 120* with or without it. You can pick it up at most hobby shops I just never thought of using it on the disco you got me thinking now.....
Old May 24, 2011 | 12:32 PM
swank1975's Avatar
sweet.
Old May 24, 2011 | 06:46 PM
Danny Lee 97 Disco's Avatar
I WAS AN aVIATION ELECTRICIAN IN THE NAVY.
ALL CONNECTORS ON OUR AIRCRAFT HAD POTTING MATERIAL SEALING THE CONNECTOR AND MOST ELECTRONICS HAD SOME TYPE OF ENCAPSULATION.
GOOD RECCOMENDATION I THINK.
Old May 24, 2011 | 06:54 PM
moomoo's Avatar
why not dunk the case in dip it...it is the case bubbleing away that usually allows corrosion and water in. That might be silly but that is what I was thinking
moomoo's Avatar
you could always make an otter box for it.....
Old May 24, 2011 | 07:02 PM
That would be mean to the otters. Why would you treat an otter like that?
I was considering re-routing the wiring and mounting the ECU inside the vehicle.
Old May 24, 2011 | 09:37 PM
moomoo's Avatar
Now we know why the nauga's hide !
you know re routing probably wouldn't be very hard with the wiring right there you could probably put it under the glove box somewhere hmmm
