waterproofing electirical and ecm
Old May 21, 2013 | 01:46 PM
TOM R's Avatar
Default waterproofing electirical and ecm
ok I see reference to buying some stuff to dip the ecm or spraying it with lacquer?
harness plugs seem straight forward just goop with dielectric grease and re plug in
would like to do this while engine is apart
Old May 21, 2013 | 02:37 PM
TOM R's Avatar
Old May 21, 2013 | 04:56 PM
TOM R's Avatar
Old May 22, 2013 | 12:45 AM
keoni004's Avatar
I'm interested too...haven't found much beyond dielectric grease that didn't lead to other issues.
Old May 22, 2013 | 08:06 AM
TOM R's Avatar
well I ordered the can in the second link? the acrylic lacquer spray mostly cause it dries faster, the silicone looked like 48 hours + to dry
says for high temp electronics, static protection, high moisture area protection , arcing etc. I am gonna assume it is what they spray on the copper wiring inside electric motors and alternators
Old May 22, 2013 | 03:04 PM
TOM R's Avatar
my ecm is dated 4197, opened it up and it is already coated should I still spray another coat?
Old May 22, 2013 | 08:52 PM
honda50r's Avatar
Keep us in the loop with your results
Old May 22, 2013 | 09:17 PM
TOM R's Avatar
here is what the inside of the ECM looks like
Old May 22, 2013 | 09:20 PM
TOM R's Avatar
outside the case looks like crap, inside the boards look like new probly cause they are coated, the drain in the case looks like a 1 way valve, but the case is not sealed in any way, think I may re-spray everything and spray the inside of the case
Old May 23, 2013 | 04:00 PM
TOM R's Avatar
ok so the spray showed up, went on no problem it dries like a flat clear coat with a bluish hue, can says UV reactive for QC tried to take pics but I don't think they really show up, also sprayed the case and covers inside and out can also product is UL listed, unless I go to start the rover and the ECM shorts out I will probly start using this on all the ECU boards when I need to service them
