Weird rim issue
Old 12-14-2015, 01:21 PM
BlueB3's Avatar
Default Weird rim issue
So on my new to me Disco, I took it down to the local tire shop for a new set of shoes. 4/5 went on great, the 5th one... not so much. They blew up 4 tires trying to get it to seat on the rim. The rim itself has an extra lip on the inside of the barrel, and it was causing MAJOR issues. They have the rim at the shop still, as I had to get back to work (2.5 hours there!) Other than sourcing a new rim, what are my options? Grinding down the lip? (it has a hard edge, a couple mm thick)
Old 12-14-2015, 01:30 PM
jafir's Avatar
They all have that lip. It's there on purpose to help keep the bead sealed if off road. It shouldn't be a problem. Maybe they need to lube it up before installing the tire.
Old 12-14-2015, 01:34 PM
BlueB3's Avatar
Like I said, the other 4 went on smooth, this one is just nuts. It feels way more pronounced than the others.
Old 12-14-2015, 01:35 PM
jafir's Avatar
It's had a tire on it before, right? It's a design feature.
Old 12-14-2015, 01:36 PM
fishEH's Avatar
Stock alloys??
Sometimes the stock alloys flake and can cause sealing issues. Did they clean up the surface before mounting?
Old 12-14-2015, 01:39 PM
jafir's Avatar
Did they lube it up? Soapy water? Maybe something like this: Murphy's Euro White Tire Mounting Paste Alloy Wheel Mount
Old 12-14-2015, 02:09 PM
BlueB3's Avatar
Yup, like I said, all the others were fine, this one, the lip seems like it's higher, more pronounced, and just wouldn't let the tire slip on. It literally blew the sidewall out in 2 spots. The poor guy airing it up about **** himself.
And yes, it had a tire on it before, stock 16" alloys. They lubed it up like mad, and all 5 guys tried mounting a tire on it, since the first guy said he was done with it, and went to lunch
Old 12-16-2015, 08:32 AM
TOM R's Avatar
Lip is to keep tires on bead when aired down, I had some trouble getting my tires off but no issues mounting them
I always do the tire soap on tire bead for mounting
Old 12-16-2015, 10:14 AM
BlueB3's Avatar
I go back today to pick up my rim.
Old 12-16-2015, 11:05 AM
jafir's Avatar
Post some pics when you get the wheel back. What kind and size of tires are they installing?
Quick Reply: Weird rim issue
