Weird vib
Old 11-22-2010, 08:14 AM
thehun's Avatar
Default Weird vib
This has got me tangled...
I just got my TF kit in...nice and lifted....im letting them settle before measurements...but this is weird...
I can be driving my landy for 5-10 min no vibs or nothing..than it vibes for 30 sec or so..goes away..its very intermit...if its u joints..it do it all the time....no idea...
Old 11-22-2010, 09:41 AM
Long Haul's Avatar
Mine did the same thing after I put my 3" under it. It ended up being the U joint on the front shaft at the transfer case. Try taking out your front shaft and locking the CDL and drive around for a few miles see if the vibe goes away.
Old 11-22-2010, 10:13 AM
thehun's Avatar
will do...i'll prolly take it to my driveshaft shop and have them replace the u joints
let me ask this..are u joints a pain to install?
Old 11-22-2010, 11:33 AM
Long Haul's Avatar
There not bad to replace. I can do them in about 45 min for both doing them with my press. Ive also done them trailside using a hammer and a few sockets (not near as easy) but if you have a bbig vise there not bad to do either
Old 11-22-2010, 03:02 PM
Make sure you inspect your rotoflex before you replace u-joints.
And if you do have a bad u-joint make sure you replace them all.
Old 11-22-2010, 03:16 PM
thehun's Avatar
I dont have a rotoflex...
Getting a u joint tool rented from autozone..but getting precision joints from o'reilys.
I knew there was something wrong, even with the wore out suspension i felt it a bit....the new suspension just made it more obvious.
All four will be replaced.
what socket does it take? the flange bolts
Old 11-22-2010, 03:42 PM
I think its 9/16".
They have Loc-Tite on them.
Old 11-22-2010, 07:54 PM
thehun's Avatar
thank you sir...did D1 have rotoflex? cause mine sure does not
Old 11-22-2010, 08:39 PM
thehun's Avatar
another reason i think its the u joints..cause when i lube them..only one joint has the lube coming out of it not all four
Old 11-22-2010, 09:05 PM
There are 2? years of DI with 4 u-joints. I know for sure late model year '97's have 4 u-joints as well as all '98's, not sure about '99 DI's.
Quick Reply: Weird vib
