Weird vib
Old 11-25-2010, 09:31 AM
That might be the problem, everything is at to much of a angle and it cant take the stress, eventually something will break.
However I ma no expert on anything especially lifts.
I do know that if you go over 3" you will have serious problems but 2" is safe.
  #22
Old 11-25-2010, 10:09 AM
thehun's Avatar
suppose to be 2" but it lifted it waaaaaaaaay more than that...only thing that sucks...is I have to drive it Fri cause i work..saturday I can drive my wife's car..sunday ill take it to my buddies and do something
  #23
Old 11-25-2010, 10:27 AM
I may have missed where you already said this but...what lift kit did you use?
  #24
Old 11-25-2010, 10:41 AM
thehun's Avatar
Terrafirma HD 2"...got way more than 2"
  #25
Old 11-25-2010, 10:42 AM
thehun's Avatar
more like 3.5"....i dont want to put the stock springs back in...I will prolly cut a 1.25 coil off the front and .5 coil in the back to bring her back down to about a 2" lift...
  #26
Old 11-25-2010, 10:58 AM
n2xlr8n's Avatar
4th Gear
I may have missed something, but before I did anything drastic, I would remove the front dshaft, see if the vibe is still there. If so, re-clock the rear dshaft until the vibe goes away (or not). Many cars and trucks shafts are balanced in a particular orientation. My .02
S.
  #27
Old 11-25-2010, 11:48 AM
thehun's Avatar
Honestly would a d2 shaft or radius arms fix my problem. Shaft will cone out Sunday on the front
  #28
Old 11-25-2010, 06:09 PM
thehun's Avatar
Took the the drive shaft out...vibs are gone...so it has to be the shaft...too much lift and the stock d1 shaft cant cope with it i would say...you guys think a double cardan would cure it? i think so...
  #29
Old 11-25-2010, 07:12 PM
hehehe...hehe...hehe...
  #30
Old 11-25-2010, 07:14 PM
Yes a double cardon will take care of this, thats why they run one in the DII.
No I do not know if a DII front prop shaft will work on a DI, however you can get a used one for cheap from a salvage yard and try it out.
Then if it fits and cures the vibration then have it rebuilt with greasable u-joints and centering ball kit.
Quick Reply: Weird vib
