Well here it goes. Head Gasket Repair.
Old Aug 15, 2010 | 07:40 PM
  #31
Spencerfitch's Avatar
I just went start it up agian. Same thing, had to give it gas and it held idle at 2500. Then I hit the gas and let it go and it seemed to steady around 1000RPM. Im not worried about it or anything.
Old Aug 16, 2010 | 07:05 PM
  #32
I found the leak, it was at the fuel pressure regulator. It was leaking a bit. I believe this may fix my startup issue. I began by stripping the nut out that holds the regulator. Then I replaced the stock hard gasket with a fuel injector o-ring and it stoped the leak, but Im going to get a longer bolt and a nut to fix the regulator the right way.
So only thing holding me up is one nut.
Old Aug 16, 2010 | 08:30 PM
  #33
vandev's Avatar
Default one nut...
one nut...thats funny....
Old Aug 17, 2010 | 12:41 PM
  #34
SHE LIVES!!
And feels like she has WAY more low end power. Im sure its in my head.
Only issue is, it sounds like I have a pully squeak. going to go check on that.
CaptainCulp
Dec 23, 2013 08:31 AM
marlymarl
Apr 21, 2012 12:49 PM
happyD1owner
Sep 24, 2010 05:46 PM
jdelp
Jul 17, 2007 06:46 PM
Pawpower
Nov 10, 2006 05:03 PM
