Well, this is strange!!
Alright, I've noticed the light flickering running through the forest at night for months now, and watched the temp gauge dance with the left turn signal since I bought the truck, but today, I was driving home and hit a snow squall & turned my headlights on. When I got to the other side, I glanced down at the speedo, and was surprised to see my temp gauge climbing right along with the gas gauge (had a half tank, but the gauge showed way over full & the temp gauge was maxed)!! Turned the lights off & both dropped back to normal. Turned them back on & within a few minutes, they were raising again. and so on (actually got amused & tried it several times with the same with the same result). The volts & temp on the Ultragauge never reflected this, and the vehicle ran the same all the way through this. has anyone ever experienced this? Could this possibly be the light/turn signal stalk causing this?
Will do!! But I have a quick question before I do. I leave the original ground to the frame intact when I use the jumper cable? This is a secondary ground, right?
Tried the jumper cable and cleaning grounds, wires etc. which didn't help on mine. I did notice at higher speeds the problem went away. I then tried running without the belt (only a short time) and the flicker went away too. I ended up replacing the Alternator which fixed it.
Does sound like a bad ground for the gauges to act up like that.
Update.... Okay, checked the ground, and added a ground wire to the radiator mounting bracket with no difference (lights still flicker, gauges still rise when I turn on the lights, and the volts drop to 11.5ish). However, I noticed something even more strange last night & this morning. If I start the LR and drive with the lights on for about 3 miles & turn it off for about 5 minutes and start it again, the lights don't flicker, the gauges are steady, and the UltraGauge volts run at about 13.3 consistently. Ideas?
