What brand/weight Oil do you use?
Old Mar 15, 2011 | 10:04 AM
Crusader's Avatar
4wd High
Default What brand/weight Oil do you use?
What brand of oil do you prefer to use in your Discos? What has seemed to work best for you so far?
Old Mar 15, 2011 | 10:31 AM
Cosmic88's Avatar
Keep in mind I am in an area which is (almost) always warm or HOT.
Engine - Shell T6
Diffs - 85w 140
R380 - Redline MTL 70w 80
and for those special occasions, KY
Old Mar 15, 2011 | 10:43 AM
jafir's Avatar
Let me tell you a little something about oil... just kiddin'
Old Mar 15, 2011 | 11:24 AM
hilltoppersx's Avatar
depends on where you live. is that Orange County in NY, CA or FL?
im in NY i switch weights from summer to winter but always use Shell Rotella T6
Old Mar 15, 2011 | 11:59 AM
bmxermike's Avatar
Castrol GTX High Milage 10/40 all year round for the past few years. Going to try out 25/40 when it starts to get a little warmer. I'm going to test oil pressure with the 10/40; cold and warm, at idle and high rpm, then test with the 25/40 and see what happens.
Old Mar 15, 2011 | 01:16 PM
Chris-bob's Avatar
I don't use oil...costs too much. Just put water in her.
Old Mar 15, 2011 | 01:17 PM
jafir's Avatar
It's going to leak out anyway.
Old Mar 16, 2011 | 09:12 AM
XCELLER8's Avatar
Engine - Shell T6
Diffs - 85w 140
hey, is the special occasion lube only available in one viscosity, or is there a winter weight available also ? It's possible to have a special occasion at 30 below here in the north.
Old Mar 16, 2011 | 10:12 AM
Chris-bob's Avatar
You can make your own 'special occasion' lube fairly easily. You get a high maintenance, but great looking lube and pour it into the engine using a small black dress as a screen/filter.
Old Mar 16, 2011 | 11:49 AM
XCELLER8's Avatar
Thumbs up
that's what I like about this forum, no matter WHAT the situation, there's always someone with helpfull advice !
