What doesn't work on your Discovery?
#43
After that hg job I did, she(Mandy) better STFU!
Here is a list of what I fixed.
T-stat
Water pump
Clutch fan
3 power steer hoses
Lower rad hoses
Ignition coil
Distributor cap and rotor
Spark plugs and wires(then the shop put in new ones)
Shop adjusted timing after it failed inspection.
Rad rodded and cleaned out.
New alternator
Rear brakes
Front calipers
Rubber seals on brake fluid reservoir.
New brake fluid
Rear bumper end caps
New rear bumper turn lamps
Condenser fan motors
Rotary coupler
Sag in drivers seat
Moon roof leaks
IAC valve
Head, valley pan, valve cover gaskets.
Pending work
New shocks and springs
New tires(bf ko's)
Tie rods
Fuel tank vent hose leak
Fuel pump(find out why it marks wrong)
Door locks
Head liner
Cabin filter
Find that brake fluid leak.
FIND THOSE DAMN WATER LEAKS!!!
Good thing is I have no fluid leaks.(oil, steer, tran or coolant)
T-stat
Water pump
Clutch fan
3 power steer hoses
Lower rad hoses
Ignition coil
New alternator
Rear brakes
Front calipers
New brake fluid
Rotary coupler
Sag in drivers seat
Moon roof leaks
IAC valve
Pending work
New tires(bf ko's)
Tie rods
Door locks
Head liner
Cabin filter
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
#45
Oh boy, 98 Disco I (stock) is running great, but ...
Thermostat (runs cold) -- have tstat need to put in
Fuel temp sensor (runs rough when warm starting) -- have replacement
Leak in steering hoses (not bad)
Pinion seal leak (not bad enough to pool on ground; maybe blocked breather??)
Slow battery drain -- unidentified
Miscellaneous electrical stuff:
- rear window; passenger power seat; driver power seat only works if door is open (wtf?); radio code; who knows what else I haven't even tried
Cracked windshield (because I was careless with the snowblower)
Cracked cargo window seal
T-case shifter: needs cleaning, sometimes hard to get neutral alarm or CDL light to go off.
#46
lol
#49
