What doesn't work on your Discovery?
Old May 16, 2013 | 07:21 AM
  #41
tooltech's Avatar
Hahaha!!
You're right Buzz.. I might need them one day. But not as much as this healthy dose of humility..
Old May 16, 2013 | 07:33 AM
  #42
CUpgt's Avatar
When are you guys gonna fix some of these simple problems????
I was thinking the same thinking the same thing!
Old May 16, 2013 | 08:20 AM
  #43
Sam95disco's Avatar
After that hg job I did, she(Mandy) better STFU!
Here is a list of what I fixed.
T-stat
Water pump
Clutch fan
3 power steer hoses
Lower rad hoses
Ignition coil
Distributor cap and rotor
Spark plugs and wires(then the shop put in new ones)
Shop adjusted timing after it failed inspection.
Rad rodded and cleaned out.
New alternator
Rear brakes
Front calipers
Rubber seals on brake fluid reservoir.
New brake fluid
Rear bumper end caps
New rear bumper turn lamps
Condenser fan motors
Rotary coupler
Sag in drivers seat
Moon roof leaks
IAC valve
Head, valley pan, valve cover gaskets.
Pending work
New shocks and springs
New tires(bf ko's)
Tie rods
Fuel tank vent hose leak
Fuel pump(find out why it marks wrong)
Door locks
Head liner
Cabin filter
Find that brake fluid leak.
FIND THOSE DAMN WATER LEAKS!!!
Good thing is I have no fluid leaks.(oil, steer, tran or coolant)
Old May 16, 2013 | 09:00 AM
  #44
TOM R's Avatar
well after last nights rain I have both front floors soaked, I just had the sunroofs out and the drains looked fine so assuming the roof rack is leaking add it to the list
Old May 16, 2013 | 10:52 AM
  #45
bigbalu's Avatar
Oh boy, 98 Disco I (stock) is running great, but ...
Thermostat (runs cold) -- have tstat need to put in
Fuel temp sensor (runs rough when warm starting) -- have replacement
Leak in steering hoses (not bad)
Pinion seal leak (not bad enough to pool on ground; maybe blocked breather??)
Slow battery drain -- unidentified
Miscellaneous electrical stuff:
- rear window; passenger power seat; driver power seat only works if door is open (wtf?); radio code; who knows what else I haven't even tried
Cracked windshield (because I was careless with the snowblower)
Cracked cargo window seal
T-case shifter: needs cleaning, sometimes hard to get neutral alarm or CDL light to go off.
Old May 16, 2013 | 12:10 PM
  #46
Sam95disco's Avatar
So you post what's broke here, then to the "what did you do today" thread to post that you fixed it.
lol
Old May 16, 2013 | 12:27 PM
  #47
CUpgt's Avatar
I've got to nail down leaks as well. Most annoying thing with my truck right now.
Old May 16, 2013 | 01:39 PM
  #48
TOM R's Avatar
I am guessing the headliner has to come out again to reseal the roof rack? if so I will just rtv around the base
Old May 16, 2013 | 09:20 PM
  #49
Sam95disco's Avatar
Man I'm not taking anything down, I have the rear ac. I know I'll break all kinds of crap. I'm going to just seal from outside to.
Old May 17, 2013 | 07:53 AM
  #50
TOM R's Avatar
I have rear a/c and already had the hl out once it is a pita by yourself, maybe I can remove some trim and drop it to access the bolts
