What the heck Rover Gods?
Old May 9, 2012 | 11:27 AM
Chris-bob's Avatar
I need to replace the tensioner as well on my D1...
Old May 9, 2012 | 12:47 PM
Danny Lee 97 Disco's Avatar
Originally Posted by calebbo
When I turn the tensioner it has a low grinding noise. The rest of them turn without a sound, though some easier than others.
You could try either blowing it out with compressed air or possibly spraying some wd40, pb blaster or something around all that and see if it helps.
Old May 9, 2012 | 03:39 PM
psykokid's Avatar
I recently replaced the tensioner on my truck. i had picked up the correct bearing but couldnt get the dam circlip out of the stock tensioner and ended up saying eff it and went and picked up a tensioner from autozone for 20 bucks. Not the same as the cast iron oe rover one, its a steel pulley with the bearing pressed in but got rid of the funky noises i was getting from my belt line.
Old May 9, 2012 | 03:46 PM
Chris-bob's Avatar
Part numbers for the $20 one or it didn't happen.
Old May 9, 2012 | 06:05 PM
calebbo's Avatar
Forealz, I can't find one that's not cheaper than $90
Old May 9, 2012 | 07:51 PM
I did the same thing 4? years ago.
Duralast/Belt Tensioner (231081) | 1997 Land Rover Discovery 8 Cylinders 2 4.0L MFI OHV | AutoZone.com
All you need to replace is the pulley, the bearing is bad, thats whats making the noise.
Remove the belt, unbolt the pulley, put new pulley on, put belt back.
15 min and you're done.
Old May 9, 2012 | 08:26 PM
calebbo's Avatar
ohhhh, see I think chris-bob and I were thinking of the whole assembly. My bad
Old May 9, 2012 | 08:50 PM
Good to know, add that to the tech section maybe.
Old May 10, 2012 | 10:41 AM
Chris-bob's Avatar
Yeah, I can find Pulleys for $20, but not Tensioners...I need to replace the tensioner.
Old May 10, 2012 | 12:08 PM
Have you tried the dismantlers (Paul & Will)?
