What is this part?
Old Sep 14, 2017 | 03:07 PM
Noodles128's Avatar
Default What is this part?
Driving from one job to another I heard a clank when I hit a pot hole then dragging. Parked at work tried to look under car a but to see what it was. Not sure what part it is since I was already running late for work couldn't slide under any help would be grateful right about now. Looking to be hanging in between the wheels on one side. At work till midnight so can't really check till I get out
Sorry for ghe bad picture quality took the pics quick.
Old Sep 14, 2017 | 03:24 PM
whiskeynipple0088's Avatar
the steering stabilizing
zip tie or safety wire it up till you can repair if stranded
Old Sep 14, 2017 | 04:18 PM
Noodles128's Avatar
Thanks alot guys for the help. I found some zip ties here at work...ill secure it tonight when I get out
Old Sep 14, 2017 | 05:17 PM
OverRover's Avatar
Noodles, slight change of plans... don't secure the damper to the track rod. With your first turn it will just fall back off.
Instead tie/rope it to the Anti-Sway Bar (see pic). A piece of rope is going to work best. This is going to be the same process and effort, but the damper will remain secure (up and out of the way) for the ride home.
Shiftonthefly1
Mar 13, 2015 01:17 PM
DonRW2007
Jan 6, 2014 09:19 AM
bosshogt
Mar 31, 2010 02:54 PM
jg123
Mar 3, 2005 11:44 AM
