what's this green fluid?
Old Feb 5, 2011 | 03:14 PM
lordmorpheus's Avatar
I feel so.......funky!!!
Old Feb 5, 2011 | 08:07 PM
COOTER-GUY's Avatar
You must have ran over a Predator on your way home. On a serious note though looks like Florescent leak detector to me typically used in finding leaks in AC systems, or engine oil.
Old Feb 5, 2011 | 08:15 PM
That was actually my first impression before everyone got on the humorous comments. In theory though, wouldn't you know you had leak dye in something, had you owned a vehicle long enough?
Old Feb 5, 2011 | 10:02 PM
Rover Chris's Avatar
no leak detector (that I know of) the A/C works and has since I bought it, and the oil has been changed a handful of times.
Old Feb 6, 2011 | 12:46 AM
Henrici's Avatar
It sounds like that stuff you put in your tires in case you run over a nail or something........
http://www.slime.com/category_3_Tire-Sealant.html
Did you run over anything?
Old Feb 6, 2011 | 11:32 AM
COOTER-GUY's Avatar
Not if the AC had been serviced for a leak before you bought the vehicle the dye stays in the system. Could also have been from another vehicle on the road and he just happened to run through it and that is where it ended up
Old Feb 6, 2011 | 01:03 PM
Danny Lee 97 Disco's Avatar
Clean it off and see if it comes back.
Old Feb 6, 2011 | 04:06 PM
thehun's Avatar
Antifreeze...prolly got a leaking core plug or something
Old Feb 14, 2011 | 04:16 PM
tornado_735's Avatar
This thread came straight to mind today as I was helping a friend put a starter on his 1998 Chevy Monte Carlo. We had to remove the A/C line to make room for the starter to come out, and green crap that exact same color started dripping out. I'm going with Cooter. Where yours came from, I couldn't tell ya, but I'm going to second what he says.
Old Feb 14, 2011 | 09:52 PM
discomedic4's Avatar
I agree with the dye theory. Hit it with a UV light and see if it glows then you will know it's dye. Then go over the engine well and see if anything lights up as far as a source. Good luck.
