Where to buy 98 disco sender unit cheap
Old Jun 19, 2011 | 08:22 AM
coldstart's Avatar
Default Where to buy 98 disco sender unit cheap
I would like to know where to buy the sender unit for the 98 disco , mine is bad and I also need the electrical connectors as well thanks Peter
Old Jun 19, 2011 | 10:15 AM
jafir's Avatar
I'm assuming you are talking about the sending unit for the fuel gauge. You cannot buy it separate, as far as I know. It comes with the fuel pump. You might see if anyone who has replaced their entire pump kept the old one. I did, and I was glad I did, because I had to use parts for the sending unit almost immediately, the plastic on the new one wasn't molded very well and it wouldn't stay together.
Old Jun 19, 2011 | 11:12 AM
Be more specific so we are no guessing as to what parts you may need.
Old Jun 19, 2011 | 02:53 PM
kenk's Avatar
I have 2 sending units(good, bad pump). If by electrical connector, you mean the harness on the vehicle that plugs into the sending unit, I couldn't help ya.
Old Jun 19, 2011 | 08:51 PM
wheelgarage's Avatar
@coldstart: I might have the same issue, but how did you know it is the sending unit from the pump assembly.
@kenk: BTW, how much do you want for the bad one?
Old Jun 20, 2011 | 08:31 AM
kenk's Avatar
Let me make sure I still have both(I like to keep 1 as a spare), but being I'm not in the parts business, I'd probably let in go for ten bucks if you pay shipping
Old Jun 20, 2011 | 09:54 AM
Sounds good....will PM you.
Old Jun 20, 2011 | 11:00 AM
kenk's Avatar
pics: BTW, it's not broke, the bottom snaps on and off with tabs.
Attached Thumbnails Where to buy 98 disco sender unit cheap-dsc00364.jpg   Where to buy 98 disco sender unit cheap-dsc00365.jpg
Old Jun 20, 2011 | 11:02 AM
coldstart's Avatar
yes it is a fuel sender unit that I need complete the pump works but the pipes coming out are rotted I would be happy to buy a used one but I thought I read somewhere someone got a new one for about 100.00 thanks Peter
Old Jun 20, 2011 | 11:17 AM
kenk's Avatar
You can get a new pump(motor, minus sending unit) for right around, just under a hundred bucks. I couldn't find a complete unit for under about $375, and I dont even remember where it was that cheap.
The pre-AEL(before mid-'97) can be had on the cheap, but won't work for an AEL app.
