Who's a dumb @$$?
uh... that would be me this time.
Normally I confine my thoughtlessness (stupidity) to forgetting to put the heat shrink tubing on the wire BEFORE I crimp the end... admit it, you've done that...
This time I was up in the Georgia Mountains (SOLAROS this past weekend) on a few warm up trails before hitting Beasley. I, as a Land Rover owner for many years now, decided to just check things out under the hood at the top of a trail as we took a break, and found a bit of steering fulid leaking from one of the hose clamp fittings at the bottom of the resevoir. Hmmm... turns out to be a small crack in the hose. NO PROBLEM as I am a rolling garage! I proceed to repair the hose end, retighten clamps and refill the res to the correct level. Off we go with no problems and tons of fun, except for our buddies '85 Jeep when its T-case exploded AFTER exiting Besley **** thankfully. Literally blew the top off!
So on the way home down I-75 my CEL starts staring at me with code 44 (OBDI... not II). Again, not a problem until we get home.
Short story long... When I filled the resevoir to the "correct" level I did NOT take into consideration the angle of the truck and apparently over-filled the res. When the fluid overflowed on the highway at highway speeds a small amount of fluid made its way into the air filter box and into the MAF...causing the ECM to richen the mix and throw the code. Cleaned it all up, changed out the air filter and we are good to go now.
Don't fill the steering resevoir on an angle, was my lesson for the day.
Normally I confine my thoughtlessness (stupidity) to forgetting to put the heat shrink tubing on the wire BEFORE I crimp the end... admit it, you've done that...This time I was up in the Georgia Mountains (SOLAROS this past weekend) on a few warm up trails before hitting Beasley. I, as a Land Rover owner for many years now, decided to just check things out under the hood at the top of a trail as we took a break, and found a bit of steering fulid leaking from one of the hose clamp fittings at the bottom of the resevoir. Hmmm... turns out to be a small crack in the hose. NO PROBLEM as I am a rolling garage! I proceed to repair the hose end, retighten clamps and refill the res to the correct level. Off we go with no problems and tons of fun, except for our buddies '85 Jeep when its T-case exploded AFTER exiting Besley **** thankfully. Literally blew the top off!
Yes she did... in fact she ran great with no idle probs or any rough running at all until yesterday afternoon. the idle started getting a bit high... then low... then high... you know the story.
I'm confident in my wrenchin abilities and engineering knowledge but man was that dumb. Hey, if you don't laugh at your own mistakes then you've got BIG problems.
Spike,as a moderator your supposed to be impartial.Thus DII bashing is unacceptable.And remember jealously is the most sincere form of flattery.(btw any word on that DII custom rear bumper??? I've got cash in the kiddy!!!!
this time im just going to gun it and try and clear the back end of my truck! lol. dukes of hazard style.
