wierd drivability
wierd drivability
So Friday I go to work and rover has a hiccup just before I get on the hi way I figure no biggie, get to top of ramp to merge and no power, I only have 3 miles or so to work and drive the entire time pedal to floor 50 MPH with popping
Get there look under hood and all I see wrong was the pcv hose on drivers valve cover has split open
Got it limped home later that day, called Justin for a hose, I put the hose on yesterday and decided to throw the fuel pressure gauge on, 26/28 psi, it holds when I rev it
Any ideas of things to look at, I do not know if the hose resolved my issue have not driven yet
No codes, sensor values all look good
Tom this just reminded me of a similar problem I had. It turned out to be a knock sensor. It didn't throw a code for a couple of days, then the wire (which was somehow on the exhaust manifold) burned through. That's when I got a code. But it ran just as you described with and without the code. It was also accompanied by engine knock, which I though was just bad gas (until I got the code).
