wierd drivability
Old Apr 6, 2016 | 07:29 AM
TOM R's Avatar
Default wierd drivability
So Friday I go to work and rover has a hiccup just before I get on the hi way I figure no biggie, get to top of ramp to merge and no power, I only have 3 miles or so to work and drive the entire time pedal to floor 50 MPH with popping
Get there look under hood and all I see wrong was the pcv hose on drivers valve cover has split open
Got it limped home later that day, called Justin for a hose, I put the hose on yesterday and decided to throw the fuel pressure gauge on, 26/28 psi, it holds when I rev it
Any ideas of things to look at, I do not know if the hose resolved my issue have not driven yet
No codes, sensor values all look good
Old Apr 6, 2016 | 07:59 AM
Charlie_V's Avatar
I bet that fixed it. That split hose made for a vacuum leak, for sure.
Old Apr 6, 2016 | 08:38 AM
hrhoward's Avatar
What is your fp under load?
Old Apr 7, 2016 | 08:30 AM
TOM R's Avatar
When I raise the rpm it maintains the pressure, already did the pressure regulator previously
Old Apr 7, 2016 | 09:58 AM
hrhoward's Avatar
If the the split hose didn't cure it the only thing other thing that comes to mind is spark.
Old Apr 7, 2016 | 12:12 PM
TOM R's Avatar
Yeah I was thinking crank sensor
Old Apr 7, 2016 | 01:17 PM
Charlie_V's Avatar
Tom this just reminded me of a similar problem I had. It turned out to be a knock sensor. It didn't throw a code for a couple of days, then the wire (which was somehow on the exhaust manifold) burned through. That's when I got a code. But it ran just as you described with and without the code. It was also accompanied by engine knock, which I though was just bad gas (until I got the code).
Old Apr 7, 2016 | 06:31 PM
TOM R's Avatar
OK I'll ad it to the list lol
Old Apr 19, 2016 | 06:48 PM
TOM R's Avatar
Actual answer......... mass air flow sensor, threw on a spare and all is good for now
It had gotten wet at rotr guess it took a little bit to die
Old Apr 19, 2016 | 10:21 PM
Charlie_V's Avatar
Nice. We should all carry spare MAFs. Group buy?!
