Window regulator and motor 96 D1
Old Sep 8, 2012 | 12:52 PM
marjac's Avatar
Default Window regulator and motor 96 D1
My 96 D1 driver side front door window motor crapped out along with the window regulator. Need to replace entire unit. Will a D2 work.. or does anyone have a left front motor for sale. Plenty of regulator arms but no motors..
Old Sep 8, 2012 | 04:23 PM
ihscouts's Avatar
Are you sure about the motor? Window regulator rivets sheer, slides wear or break and teeth get broken so I can believe that on the drivers side. What have you done to check the motor? Try paulgrant@mac.com for the motor and possibly a regulator if your sure it's toast. I don't think the two are interchangeable between Disco and DII.
Old Sep 8, 2012 | 05:30 PM
marjac's Avatar
Thanks for the reply. But yes the motor blew apart the retaining cap was off and the internal mechanism was in shreads.. and to boot one of the nylon rollers was in two pieces as well. Thanks for the lead on parts. I will check him out.
Old Sep 8, 2012 | 09:00 PM
marjac's Avatar
Rovers North had both parts brand new! Looks like next saturday morning is planned :-)
Old Sep 15, 2012 | 12:38 PM
marjac's Avatar
Just finished the install! Start to finish about an hour. Only part issue was the electrical connectors do not match from the original wiring. Simple to resolve. Rovers North great service great parts.
RedAustinIX
Aug 10, 2020 11:43 PM
wallem
Jun 13, 2012 07:58 AM
Al Blue4.6l
Aug 14, 2011 05:28 PM
Cessna310Guy
Nov 15, 2008 07:31 AM
