wont start!
Old May 19, 2011 | 05:39 PM
dreamspawn's Avatar
Default wont start!
Ok my land rover has always started up and treated me good. Went to start today after a week and nothing just cranking. Changed plugs nothing,hooked up a light on plugs andits barly getting any spark.. so im thinking coil? Or distributor? Any way to check if coil is still good? Or any other ideas?..
Old May 19, 2011 | 05:44 PM
Chris-bob's Avatar
What kind of Land Rover? I am assuming a 3.9L because you mentioned a distributor...Are you getting fuel?
Old May 19, 2011 | 05:59 PM
Banzai Jimmy's Avatar
The Workshop manual lists the procedure to diagnose the coil, amp, etc. Start with Section 12, chapter Fault Diagnosis, page 3.
Old May 19, 2011 | 06:27 PM
dreamspawn's Avatar
Yes 3.9L disco 1
Where do i find that..
Old May 19, 2011 | 08:55 PM
Danny Lee 97 Disco's Avatar
Download the RAVE manuals from some of the signatures on here.
Old May 19, 2011 | 09:40 PM
dreamspawn's Avatar
OK, coil tested good through all the stuff in manual, so i've changed plugs, coil is good, when it cranks you still get the smell of just gas... So i'm gonna let it sit for the night and charge the battary, thinking plug wires and distributor are only 2 things left so...
Old May 20, 2011 | 12:50 AM
LeakyDisco's Avatar
Original fuel pump?
My pump on my 97 died recently (@76k miles) and it would not start/stay running unless I smacked the pump.
New pump, and it starts/runs like a charm.
Old May 20, 2011 | 08:40 AM
jafir's Avatar
Where is your ignition amplifier? If it's still on the side of the distributor, it could have failed from getting too hot.
Old May 20, 2011 | 09:54 AM
DiscoJag's Avatar
Default No Start
The fuel pump on my '96 just gave out a couple of weeks ago, and the fuel filter was clogged also, which probably contributed to the problem. Check the fuel pressure on the fuel rail by pushing on the schraeder valve or with a dial type tire guage. It's right on the fuel rail with a black tire valve type cap on it (or should have). If there is good pressure you will be able to tell. This is after turning the key on or trying to crank.
Old May 20, 2011 | 07:42 PM
dreamspawn's Avatar
Walked out this afternoon hit key fired up, misfired alittle, and had black smoke coming exhuast (fuel). Turned off put air box system back on everything back in order and hit key fired up again and ran perfect... guess it got mad i ignored it for 2 weeks...
