Working on Mutley
Old Sep 17, 2010 | 09:53 PM
georgep's Avatar
Talking Working on Mutley
Well I bought another one 1996 D1 SE for a donor for Mutley.
Mutley has been running perfect till I took the wife out. He was back to Shutting off for no reason, hit the starter and he fires back up.
This time I noted that
When running fine and you roll out of the throttle you can see the rpms GRADUAL drop as you slow.
When he acts up you roll out of the throttle and the RPM DROPS like a stone almost like you pushed in the clutch (Automatic).
Any good guess?
Old Sep 20, 2010 | 10:57 AM
okdiscoguy's Avatar
Fuel pressure? Coil? odd one...
Old Sep 20, 2010 | 11:16 AM
NiteTrain's Avatar
Ok, i've just got to see a pic of your garage...or warehouse or where ever you store all those vehicles
Old Sep 20, 2010 | 01:11 PM
discomedic4's Avatar
Do you think it is a fuel issue, like a partial blockage of a fuel line or something starving the engine temporarily? Maybe a bad VSS? Wonder if that gas tank was in the recall. During the early years of the NA Disco they had a tank issue which would eventually cause a suction in the tank, collapse of the tank, and then a cracked tank, so then you had unexpected stalls. Others on here know alot more about that issue and the recall but might be a culprit. Just throwing out ideas. You can probably search and find a few threads on the bad tank issue.
Old Sep 20, 2010 | 01:16 PM
If it will not idle but will run all day with your foot on the throttle keeping the RPM's above 500 it is a bad idle air control valve.
georgep
Sep 2, 2010 08:33 AM
georgep
Aug 25, 2010 07:10 PM
georgep
Aug 24, 2010 06:24 PM
georgep
Jul 19, 2010 08:19 AM
georgep
Jul 16, 2010 05:50 PM
