Well Mutley is SAFE
Old Sep 1, 2010 | 02:46 PM
georgep's Avatar
Default Well Mutley is SAFE
Going to just fix him and use him as purchased to run around, pick up parts and make runs to the dump. Just to good a unit to sell for $1,900.00
Range Rover is going to LR Columbia for some updates and missed service and the LR3 is going for it's 60,000 mile check at the vet.
Just need to get Mutley a window lift and fix the wires for the rear windows and all is well.
Old Sep 1, 2010 | 03:09 PM
Henrici's Avatar
When you say re-wire the rear windows are they both not working? I just did this repair (LINK) was pretty easy, by far the hardest part was getting the board it self to come out. It says to remove the two nuts that hold the front of the box that contain it, then angle the box to slide out the circuit board. After 45 angry minutes I just removed all the bolts I could see holding the metal piece that blocks it (what your glove box hinges on). Put on a glove and pulled really hard till I got the clearance needed.
Now I'm trying to figure out a cheap way to fix the widow regulator rollers in one of the rear windows. See my thread, looks like I need to head back to home depot and spend some quality time in the fasteners department. Glad to hear Mr. Mutley is safe!!
________
herbal vaporizers
Old Sep 2, 2010 | 08:33 AM
georgep's Avatar
Thank you, I have access to a parts unit so I will go see what that is all about. Guy owes me a favor so the part will be CHEAP I hope.
Took Mutley for a walk to Colombia S.C. about 120 round trip he ran great, cold air and about 17 MPG not bad for 190,000 miles.
georgep
Sep 20, 2010 01:16 PM
georgep
Aug 25, 2010 07:10 PM
georgep
Aug 24, 2010 06:24 PM
georgep
Jul 19, 2010 08:19 AM
georgep
Jul 16, 2010 05:50 PM
