yet another issue
Old Oct 19, 2010 | 07:08 PM
pwr198's Avatar
Default yet another issue
fix one find one. Now when I make a tight turn I hear a clicking sound?
Old Oct 19, 2010 | 07:28 PM
NiteTrain's Avatar
probably CV joint going out
Old Oct 19, 2010 | 07:49 PM
geek_IM's Avatar
Or a rock stuck in his tire.
Dude, seriously, wtf
more info = better help. Nobody can give you any kind of help off a one sentence post like that.
Old Oct 20, 2010 | 08:49 AM
okdiscoguy's Avatar
I am leaning towards CV as well. Have someone make tight turns in a parking lot while you listen from the outside.
Old Oct 20, 2010 | 09:09 PM
XCELLER8's Avatar
3x on the cv............mine did that when I first got it.....supposedly thats why the po got rid of it. When I went to replace it I found that it was bone dry...no gear lube , no grease. Let us know what you find
Old Oct 20, 2010 | 09:44 PM
Danny Lee 97 Disco's Avatar
My Bridgestone Duelers are terrible about picking up gravel from my driveway. You'll be driving along with ticking noises driving you crazy and it turns out to be a few little pieces of gravel in the tread grooves.
Old Oct 20, 2010 | 11:29 PM
bmxermike's Avatar
I have those tires too, looked around under the truck after every drive because of it for awhile.
Old Oct 21, 2010 | 09:34 AM
So, lets get away from the rocks and back to what is most likely starting to fail. When was the last time you did a complete front diff. service, bearings Swivel fluid, seal and a setting of the preload? You may be out of swivel oil, causing the cv joint to talk to you. There is a slight chance, depending on it mileage and how low the fluid is, that you may prolong it's death by filling both swivels.
Old Oct 21, 2010 | 09:43 AM
jbriggs's Avatar
Ditto what Mike said. I filled both my swivels while I'm waiting on the CV joints to arrive. Lock it in 4 wheel and turn it and if it clatters like a B**** it's your CV joint.
Old Oct 21, 2010 | 05:53 PM
pwr198's Avatar
how and where do you fill the swivals
