"well used" example
Old Dec 18, 2006 | 12:53 PM
apcollin's Avatar
Default "well used" example
I'm looking to pick up a Discovery I and found one with all the options I like, with a few qualms.
1995
-191k miles
-Tiny spots of rust on the rear bumper, another spec of surface rust in a door jamb
-some surface rust underbody
-SRS light on
-rear sunroof raises and retracts, but does not slide back
-headliner sagging a bit
-tried to figure out if it was leaking oil, but to be honest i couldn't really tell (smelled a little like it)... seemed like it might have at one time been leaking and the block was never cleaned off.
Should the mileage alone be cause for concern?
I took it out for a test drive, however, and it sounded/pulled quite well. Plus he's asking $2,100, which seemed pretty cheap to me.
Thanks for any input
Old Dec 18, 2006 | 06:17 PM
98roverguy's Avatar
Default RE: "well used" example
I'd push for under 2k. If the srs is on it may have been in an accident, but who knows. That is a lot of mileage but I guess it really depends on what you plan on doing with it etc. if you really want it get for at least just under 2k imo. Good luck!
BajaXJ92
Dec 13, 2009 09:35 PM
