$1100+ for fuel pump repair
Old 06-18-2009, 03:10 PM
britbranch's Avatar
4wd High
wow.. thanks! I will give them a call... but are you suggesting to fix it myself?
Old 06-18-2009, 03:12 PM
britbranch's Avatar
4wd High
also, does the discovery I definitely not need the evaporative recovery unit?
Old 06-18-2009, 03:19 PM
LANDZUII's Avatar
Yes its not that hard.
The Discovery I was made to be fixed in the most remote parts of the world with
min of tools.
The only thing is that you will be working with gas and you need to make sure that
the battery is disconnected.
most places do not know that there is a port hole in the back to get to the fuel pump.
Most places will charge to drop the fuel tank and big bucks.
Old 06-18-2009, 03:23 PM
NiteTrain's Avatar
before I replaced a part that expensive I would at least pull it out and bench test it. Brit, all you need is a pair of jumper wires and your battery. Ground it and apply 12vs to see if the motor works.
Old 06-18-2009, 03:26 PM
LANDZUII's Avatar
The Evap unit is under hood and not needed when replacing the fuel pump.
My Disco I is a early one and yours is a later one the fuel pump is different than mine
so it will work with the rest of your system, as does mine just a few different parts.
I would replace the fuel filter at the sametime and that will be harder than the fuel pump.
Old 06-18-2009, 03:40 PM
britbranch's Avatar
4wd High
I already tried jumpstarting the car & it didn't work.
Also, I really am sure that I am incapable of fixing it myself... I guess I could ask someone but it at least helps to know that this shouldnt be difficult if they know how to do it correctly. Thanks!!
Any other advice is appreciated but I'll try to negotiate my cost down.
Old 06-18-2009, 03:44 PM
NiteTrain's Avatar
brit, I think you misunderstood me. I meant taking the pump out of the vehicle, placing the pump on your work bench and applying 12 volts to make the pump motor spin.
Old 06-18-2009, 04:01 PM
redhotbuzz's Avatar
Your evap number is on a sticker in the front of your engine compartment where the hood latches... Its probably AEL which is about 400 bucks fronm AB. It has a metal retaing ring that youll need to replace,,about 15 bucks ..If it has quick connect fuel lines make sure you use the right tool to remove them..I have replaced mine ,,,,one of the easier fixes imo ...Thats alot of money to spend if you can fix it yourself
Old 06-18-2009, 04:02 PM
LANDZUII's Avatar
If they have already told you its the fuel pump,, say thanks I can't afford it now and take it home and do it there.
Old 06-18-2009, 04:09 PM
llPANCHOll's Avatar
Give Mike your phone number and let him walk you through the steps to see if it truly is the fuel pump. He has your best interest in mind. He can walk you through some simple steps to see if the fuel pump is in fact broken without having to take anything apart or have any real mechanical knowedge.
Click on his name and send him a private msg
Quick Reply: $1100+ for fuel pump repair
