$600 to replace a water pump?
Old Apr 27, 2011 | 05:35 PM
primo's Avatar
8th Gear
Default $600 to replace a water pump?
Does this sound right?
Old Apr 27, 2011 | 05:37 PM
DaveBFoto's Avatar
Land Rover Water Pump: Water Pump Fits Most Land Rover Vehicle Models - Atlantic British
$109.95 for a water pump.
Old Apr 27, 2011 | 05:49 PM
ajmille's Avatar
is this with labor, if so I can sell you one for cheaper $599.99. JK if it is with labor then yes, dont bite the bullet, do it your self it is easey.
Old Apr 27, 2011 | 06:07 PM
Bundu's Avatar
Banned
$100 DIY
Contact PT P. T. Schram Rover Repair, Indiana's Finest Land Rover repair service
Old Apr 27, 2011 | 06:25 PM
buick215's Avatar
$600 sounds a little high but I have never had that done so I really don't know. One thing that I highly recommend is that you use the original Land Rover water pump. It has a solid brass impeller. The after market ones have a stamped steel impeller, cheap bearings, and don't last as long.
Old Apr 27, 2011 | 06:28 PM
mwindth's Avatar
Originally Posted by Bundu
I concur, you will need this: land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
great point buick215, I concur as well.
Old Apr 27, 2011 | 06:59 PM
fefo25's Avatar
Thats a crazy price!
Old Apr 27, 2011 | 07:14 PM
DarylJ's Avatar
Originally Posted by DaveBFoto
The labor does sound high, but you really don't want to use the $100 water pump. The OE one is about $180, and has a brass billet impeller, as opposed to the cheap-o's (at least the two I've had my hands on, including that one you linked which I sent back to AB to get the OE one) have a stamped impeller.
In my opinion, its too critical of a part to go cheap on.
Old Apr 27, 2011 | 07:38 PM
It bills out as a 1.1 hour job, so either they are charging you $500 for the water pump or they are charging you $500 per hour in labor.
Old Apr 28, 2011 | 09:04 AM
sloan74's Avatar
/this
x2
